1 - 16 of 16 Posts
I have a 2005 LT with 8500 miles on it...purchased it in March and have been extremely impressed with the bike. Here is my question: At the end of my driveway, I have a 2" lip to get to the street. Whenever I come back for a ride, I go over the lip and I hear a "thump" from the bike bottoming out. I am 220 lbs and it happens all the time. Any suggestions on this - or is this a normal thing with back shock(s) on an LT?
Thanks guys...
Glenn
Glenn;
I'm about you'r weight and had that problem when I first got my 03.......Lift the drivers seat and check the setting on the rear shock.....the adjustment is visible as soon as you lift the seat. make sure it's screwed in the 3/4 or so level.......if that doesn't work, remove it from the mounting bracket and look on the bottom. You'll see a 'banjo' fitting where the oil is transferred to the shock........carefully remove that fitting and with a hypodermic, or eye dropper OWETF, add a tiny amount of jack oil to top it off.......it won't take much, like maybe a couple of cc's but when you get it back together it will make a difference........
There is a thread here on the forum that describes it in detail.......for instance........make sure you unscrew the adjustment completely before removing the bolt that holds on the banjo fitting.......also, when you get it off, you will need to poke a piece of wood dowel inside and compress the piston all the way back before trying to refill with oil...........theres probably a couple things I'm missing here so I recommend you look up the article in HOW on the site or
Thanks for the insight. I do have the adjustment 3/4 - full. I will look online for the details of the fix.
THANKS!
Glenn
Adding the oil to the shock adjuster will make a huge difference in how much pre-load you will get. IIRC it only takes about 5 cc's of oil to fill it up.
Really quick fix too.
Loren
and as the notes say... take great care when unscrewing the banjo fitting!! There's a couple of little special copper (?) washers that will fall out very quickly and drop into the mainframe area... one of mine landed on top of the rear drive and it took me about 20 minutes to find it, got lucky just running my fingers over the drive and felt it... but for the life of me ccouldn't see it!
It does seem to make a difference though adding the extra oil...
cheers
CAUTION! This is a hijacking! :histerica
Not near as much as replacing the stock shocks with a new pair of Ohlins! :D The cost is slightly higher than a bottle of hydraulic jack oil, however.
My mom's driveway has a peak at the end where it meets the curb. Before the Ohlins, my centerstand would drag and I had to cross the peak at about a 45 degree angle. After the Ohlins, there is a little more ground clearance and I can cross the peak at 90 degrees. I'm not sure how much ground clearance I gained. We didn't do before and after measurements. Add quite a bit more lean when on the sidestand.
THANK YOU! I'm here all week. Don't forget to tip over your waitress! :histerica
Well, maybe for some of us, no amount of extra oil will make a diffrence..... Too many of Mom's cookies? :histerica
(Sorry, couldn't resist). ;-p
Mine also did that when the dealer put the incorrect tire on the rear.
The size and load range rating is on a small sticker under the seat.
Discussion Starter #13
I cannot believe such a small amout of hydaulic oil made that much of a difference but the process worked as outlined on the forum. The only issue was getting the screw unloose on the bottom of the banjo connector (if that is the correct name of it). The screw did leak a tad bit of oil on the first pass so please note that you need to really crank down hard on the screw.
Overall, it was like riding a different bike as I noticed a remarkable difference in the handling of it.
Thank you all for your help.
Glenn
PS I tried pushing down inside the adjuster but didn't notice anything that moved.
Interesting, mine "popped" in about 5-10mm (1/4 in) when I pushed down on it before topping up.
Bahh to the naysayers.. we know it works (and I cant afford Ohlins yet...) :p
I read the forum and immediately knew something was wrong on my bike. The adjustor would crank down almost to the bottom before any resistance occurred. I took it off per the instructions provided on this forum and when I pushed down on the inside of the cylinder it depresses at least an inch and a half. It held quite a bit of oil. I also filled the hose with a syringe as previously mentioned. I have yet to take the bike out but I am certain I will be able to tell the difference. Thanks for the info!!
my 2002 did-does the same thing but not every time,,i had already added oil to the ajuster a few months back,,so after i but my front tire back on i was lifting the front off the ground and letting bang back down....and the thump returned i found the front shock lower bolt was a little loose ,tighted it up no more thumping
1 - 16 of 16 Posts
