I disconnected my battery on my 2005 lt for about a month and reconnected and the fuse from horn ,brake light etc blowed ,change for new one and same thing ,bike start normal but no horn no brake light,ant-theft alam system with central locking. Can you help me
The first objective is to isolate what the cause of the problem is, obviously. If it's the same fuse setup as the pre-'05s, that fuse is for the horn, the brake lights, and the anti-theft system (if installed). I would remove the fuse and start the bike. While running, install a new fuse. If it pops instantly, it almost has to be the anti-theft system that's causing the problem. Your horn and brake light aren't being used if the bike is just parked and idling there.
