1 - 14 of 14 Posts
Folks,
My HID light kit turned up just this afternoon and i have been reading and searching the archives on hid installs others have done ,but id like to know why some many people have mounted the ballasts near the radiators for?
This seems like a crazy idea as the radiators get hot... thus transferring heat to the ballasts and who knows what damage extended heat will do to them.
So i have taken photos of the front of my bike, both left and right.
You will see there is a small ledge near the indicator.
Im seriously thinking about mounting a ballast each side of the bike on one of the ledges.
Can anyone tell my why this is not a good idea???
G'day Dez,
I have not had any issue with mounting. my HID's are each side near the radiator with about 3cm of space from the radiators. They were fitted by my bike shop and have functioned fine, I guess it is just personal choice. Remember though that you are getting air in thier when riding.
Hope it works out OK for you.
Thanks for the info Jake
Hi Dez,
My only concern with mounting the ballasts on those small ledges would be that they are not very rigid and the additional weight and in turn the flexing *may* cause them to pull away from the fairing... They are also exposed to a lot of water and grime in that location, not that they would not be able to withstand such... Have you tried the more traditional location of the ledge above the headlight?
Cheers,
I had mine installed on the ledges. The water and grime finally got to the wiring and soem of the connections were bad. I re-installed them by zip-tying them under the nose cone right behind where the mirrors attach.
Sorry no pictures , some others on here have done the same thing
Cheers
G'day Guy's,
Agree also with you Ian, On my 03 LT (RIP) I had my HID mounted on top of the light fitting, that also worked fine but did have a little bit of movement.
If you look at where HID Ballast's are mounted in cars the engine area is probably a lot hotter than bikes in that it has less air flow and is also subject to more road grime and dust. Our bikes seem to keep fairly clean around the front inside of the fairing.
Dez Once you have decided where to fit send some photo's
Maybe...for you fair weather riders ;):)
I recently placed my ballasts on the ledge you talking about. I ride in Arizona and southern California so it is rare I ride in rain. Although I appreciate Ed's comments and will I keep an eye on my ballasts to see if I have the same problem with dirt and water.
jake said:
Hey Ian,
Fair weather - Check this out
Okay mate, I'll amend my comment to lunatic riders...:):)
Looks like you are performing a very tentative, delicate u-turn there buddy...surely that bit of white stuff didn't scare you...;)
I don't think Simone was impressed. Bit icy and I made her walk a little way.
Would I do it again - no way on an LT. The hail that came later was more of a worry.
But then again it was a bit of a buzz to get through. Possibly poor judgement on my part to continue. Then again it's all part of the journey.Nothing like a bit oa adventure.
See ya
Discussion Starter #12
Thanks for the input guys. Hva e managed some time to myself tonight and pulled off the fairing left/right to get a good look at things and i have run power wires from the relay's to the front of the bike and i have run the wires to the realys from the original bike high/low wiring. not yet terminated the wires. Not yet mounted the ballasts. Still not decied on them fully yet.
But the relays im mounting them underneath my riders seat. i have seen photos of others with the nose cone removed etc,etc, and i recon it will be a pain to replace. with them under the rider seat, i just flip the seat, cut some zip zipes, replace the relay zip tie together and go again.
im mounting the realys to a relay wiring block. that way no need to unplug wires from the relay when changing relay. i will put some dielectric grease on the connectors to help prevent corrosion.
Discussion Starter #14
Colin1952 said:
Hi Dezrae. How did the HID's end up?
*AWESOME*
I mounted the hid balasts to the inside ledges on the fiarings, and Liv decided to leave me the digital camera so i have attached pix.
Next time i have the covers off i will show you how i ran the wiring along the edges.
I have included a photo of the relay blocks i installed near the battery. i made the wires long enough so i can move them out of the way to replace the battery.
For the wiring to the globes i cut a small hole for the wires to poke thru the base of the original headlight cover.
others have cut dirty great holes thru the cover then patched round the holes and it looks disgusting.
i ran the wires for the globes in the fairing of the nose near where the two holes in the nose are.I held the wires in place with 100 mph tape on the inside. i carry a roll of it in my panniers,never know when it might in handy.
to run the power leads from the battery to the front i ran the wires near the radiator to the centre of the bike then straight forwars.this way i missed the forks from lock to lock.hope his makes sense. i will shove my camera in the front end and get some photos.
Photo 1 - looking from front of bike to left side hid ballast mounted to ledge on fairing.
photo 2 - wiring near battery for relays to power hid lights.i labelled the fuse holders with a L & H (low/high)
photo 3 - where the wiring for the relays usually live
photo 4 - under the nose cone looking upwards. the big red wires are the new power cables i ran from the relays to the ballasts.the thin brown wires are the ones i ran from the high / low plugs to the relays to turn the relays on/off.
photo 5. camera sitting on the front guard looking forward. see the wires all exiting the base of the light cover. see the 100mph tape inside the fairing keeping the wires in there, see my shoulder??and again the 2 brown wires,one off the positive for low, one for positive off high beam ran to relays under seat.
i promise better photos next time i have the "Enterprise" in bits
1 - 14 of 14 Posts
