David it shows that you put a lot of effort and possess a lot of talent in editing the video.
If you have the shift-assist, then do what I do- just hold it in your hand.I own a 2016 1200RT. Not sure how to mount a Go Pro. How is everyone else mounting yours
Sugru worked fairly well. I might of had a little too much on it, used 3 packs where most use 2, so it required me working it a little more to make it look good. At some point when I was trying to mold the left side I raised up the mount (to much product) so the left side is a smidge higher than the right. Outside of that I think it turned out really really well. I'd just recommend to REALLY inspect the mount good to make sure its level. I was checking every aspect of it except the X axis...After having my XD4 for almost 4yrs I finally put a GoPro mount on my chin. I've absolutely hated not having one, finally got off my butt and got it done last night. First time I've played with Sugru, its slightly high on the right side but outside of that its fairly level lol
Going to throw the camera on it tonight since I had to wait for it to cure. Hopefully the camera angle will be alright given its not perfect.
"Power Line Rd."I have mine mounted on the GoPro bar mount but you need Illium risers. I have the GoPro 6 and stabilization is great, no shaking. I like it there because I can reach it to turn it on and off and it's not out in the elements. This is the view I have but it's adjustable and can be rotated towards or away from you. Not a pro, I just take occasional videos while riding.
