See *Similar threads* below your post. Bottom thread. Second post in that thread has a picture of the fuse blocks, and identifies the Motronic fuse location. HTH.mikey said:I am puzzled on which fuse it is to reset mine...Under the passenger seat there are 3 sets of fuses....could someone tell me which one it is as I face the Rear of the bike? tks Mikey
Just do what Alan said - disconnect the battery for a bit. Then, when you reconnect, do the TPS reset procedure.mikey said:tks folks....I did see that one earlier but I should have mentioned that I have an 03 is it still the same?
