I recently completed another failed final drive rebuild. Info posted here for those who may be interested.
Two basic points: First, the preload measurement technique originally suggested by Dman gives results very close but not exactly the same as the technique in the BMW service manual. (Since I used different measuring tools in these two techniques, the differences could be measurement error).
Secondly, and this is more speculative, is that failed drives that I have seen where the crown bearing failed, where I have been able to glean some information, had too much preload.
This final drive had the classic crown wheel bearing failure. Failure was of the retainer, attached pictures show the broken retainer. Both the innner and outer races were spalled, and it seems to me that the spalling of the races must have preceeded the failure of the retainer.
There was evidence that this drive had been rebuilt before. The bearing seat in the cover was scored, evidence of a spun bearing race, which happens when the drive is ridden for some distance after the drive begins to show signs of failure.
The current bearing did not show signs of having spun, and the history given by the rider indicated that the bike was not ridden far after evidence of failure. These findings made me think this was a twice failed drive. One failure with the current owner, one with a prior owner which the current owner had no knowledge of.
I measured for preload of a new bearing using two techniques. The BMW method requires a BMW special tool, and a slide micrometer. I developed a technique using the final drive cover in place of the special tool. Many repeated measurements give me confidence in the accuracy of the measurements.
The other method I used, originally introduced by Dman uses a dial indicator; this method is documented in my final drive rebuild video.
The two methods, both repeated several times on the current rebuild, did not give exactly the same results but quite close. (Something I have been curious about, and a reason why I was interested in doing another drive.)
Using both techniques, I arrived at a preload shim thickness of 0.20mm.
The original shimming in the drive was 0.65mm. Much thicker than my calculations for the new bearing. That doesn't tell us much since it is not possible to measure needed preload for the old, damaged bearing. But if you imagine that the bearings are manufactured pretty close to the same specs, and the the machining differences are in the final drive components: cover, housing, crownwheel assembly, tapered roller bearing and it's shim, then it would suggest that the drive may have been excessively preloaded by about 0.65mm-0.20mm= 0.45mm. (I have previously rebuild a drive that had a bearing replacement following failure without preload check, and the new bearing which was shimed using the original shims was over-shimed by 0.50mm by my calculations). This seems to me to be quite a lot of excess preload. This is fairly speculative, but both the old failed bearing and the new one are 19 ball, *** bearings made in Germany, and no other components in the final drive have been changed.
