I posted a thread earlier today, it is not showing up. That is about the fourth time that has happened. WTH?
My clutch cable seems to be or getting somewhat stiff. Just curious what the cures might be, what to look for etc. 48k miles. Still easier than any other bike I have tried, but, seems to be stiffer with colder temps. Are there splines that need to be lubed, lube the cable, a throwout bearing? There is no unusual noise.
Anyone with a Clymer manual, pg 417, top left pic. Are you supposed to pull that plug and check for anything on a routine maintenance?
Did the trans oil this AM. Unable to lift the bike on the center stand due to bad back and just can not risk it.
I put in over 1/2qt of gear oil in, the bike is almost sitting straight up. I tipped it as far as I dared, and still did not see the oil where it should be.
Don't have a CC measuring canister, so not sure how much oil it needed, or if I need to add more. Manual stated not to overfill. I went with the info on the PS service DVD.
Any thoughts on proper RPM's for downshifting...having a problem only with 4th. Been that way since we got it and I rarely used 5th to begin with. Not all that bad, and I do pre-load before shifting. Be nice if it wouldn't grind.
FD gear oil is finally clean looking. Second change in 6k miles. Engine oil is filthy, ran some Sea Foam in it last 400 miles. Trans fluid looked good too.
Thanks!
Thanks!
