I noticed a new small oil drip and traced it to the lower engine area, in font of oil filter cover plate, and below the oil pressure sending unit. Camera is laying on the floor. Top of pic is towards front wheel. The coolant temp temp sender is clearly seen on the upper right. Moving to the upper left of photo and slightly to the lower right of the oil sender, is a hole. I don't think it takes a screw, but does it? The drip appeared to be coming from directly inside the hole.
