My middle tail light is out ... swapped bulb and no go ... the one on the left and right are on so I doubt it's a fuse ... unless it has it's own? Any ideas?
Huh ??? On my 2003, I have more than one wire going to it. I assume one operates the running light, the other the stop light.DanMartin said:There is no wire going to the middle bulb.
It is a dual element bulb. Needs 3 wires going to it. Has 2. I ran a jumper from anotherlesn said:Huh ??? On my 2003, I have more than one wire going to it. I assume one operates the running light, the other the stop light.
Do you mean, you don't have a wire going to it on yours-at all ? Than what trigers it's activity.?
Forgive me....I am really green when it comes to these issues.
Excellent advice!DanMartin said:It is a dual element bulb. Needs 3 wires going to it. Has 2. I ran a jumper from another
light to activate this one.
jzeiler said:I ran a wire to mine but I put a solid state flasher in line with it. Now the middle light flashes when I hit the brakes.
Done! That brightened up my brake light a ton!DanMartin said:It is a dual element bulb. Needs 3 wires going to it. Has 2. I ran a jumper from another
jzeiler said:It has three terminals B, L and E. Run the wire from the other brake light to the "B" terminal, Then run a wire from the "L" terminal to the center bulb. The "E" terminal needs to go to ground ( Brown wire). That is it.
