Ok, I got the first part done, bleeding the part where you fill the 2 reservoirs. The rear on right side of bike ad the handlebar reservoir. But I have screwed up the bleeding with the funnel. I screwed the funnel into the hole closest to the left side. I think it is for the front. I hooked a hose to theleft front caliper bleed valve. Filled the funnel and turned on key and started squeezing the front brake lever as I opened the left caliper bleed valve. I got fluid out but the fluid in funnel is not going down. Then It looks like I am getting air out of the bleed valve. On top of that I have brake fluid coming out of the vent hoses. What the hell am I doing wrong and how bad have I screwed up?
