1 - 15 of 15 Posts
Duplicate Post Please Ignore
Picked up a 2000 LT that has been seriously neglected.
I'm putting a master repair list together to work through.
I want to get to everything while it's open. I have to replace the clutch so I'm already in it.
What am I missing? I don't want to put it all back together and then realize I forgot to replace something.
Besides the clutch and can ectomy.
Thanks for all your help.
My opinion, Id change all fluids. antifreeze, brake fluid, etc.....
I bought an 05 that was in great shape, but I have no service records of anything. I looked at my brake fluid and its dark, obviously needs changed. Since I found that, Ive decided to change out all fluids in the bike.
I would also replace the rubber fittings on the throttle bodies (head side). And the fuel injector o-rings. And the crank case breather tube. And the fuel line quick connections if they are plastic
And if she doesn't have the throttle cable update then do that too, real nice retrofit for the older LTs
Damn I thought I posted and then couldn't find it.
How do I delete it?
That is OK :)
I think because you are the OP, you are able to delete the entire thread but you now have information on both so stick with one of them if you can. If you go to your profile page by clicking on your own name, you can find in the statistics all your posts and all the threads you started. Good luck in learning to navigate. It isn't too bad after a few times round the block.
Seems you have enlisted the help of my protégé (AKA: Brother from another mother)
First and foremost: the clutch...
Call Denise Bentonville BMW 479-273-1807 - She will beat most every other resource AND no CA sales tax ([email protected])
11621744323 HEX NUT - M8 SW12 quantity 8
11627662083 GASKET RING - C32X40 quantity 4
21212332974 PRESSURE PLATE quantity 1
21212333449 HOUSING COVER quantity 1
21211454417 SCREW quantity 6
21211242377 WASHER quantity 6
23211230440 FELTRING quantity 1
46632347012 BLIND RIVET NUT quantity 4
21217688214 DIAPHRAGM SPRING quantity 1
21211451274 SPACER RING quantity 1
11117666186 SHAFT SEAL quantity 1
11211460673 HEX NUT quantity 1
11211460696 COMPRESSION RING quantity 1
11211460467 O-RING quantity 1
beemerboneyard.com
BB2122455OR Oil Proof Clutch Plate quantity 1
BBK1200LTSUPMaintkitm Complete 12/24K Mile Super Maintenance Kit With Engine Oil
BB21522333433N OUTPUT CYLINDER CLUTCH quantity 1
Ebay
Source front and rear brake pads (EBC)
beemershop.com call up ted 831-438-1100 X 113
Speigler brake lines
www.4wd.com
PC680MJ Odyssey Battery
Local
Dot 4 Brake fluid - enough to change the brake and clutch
Radiator Fluid
Medium strength loctite (blue)
6 cans of parts cleaner
box of latex gloves
miscellaneous hand tools
heat gun (Harbor Freight)
Small container of white lithium grease (swing arm boot lube)
All told your looking at about a Grand in parts, just the clutch cost me $600+ from Denise. You'll also need the contents of the box (honda molly, specialized tools, misc. parts) I'm mailing to hallzee and pray UncleMark returns the Motorcycle lift! :wave
Just finishing up on Gretchen...
Looking for the avatar "I'm not worthy"
Thanks so much Shoswell
You guys have saved me tons of time of searching around.
Many many thanks
Now the work begins...actually it already has
Many many thanks
Don't forget to drill the slave cylinder weep hole and rebuild the slave while in there.
Hallzee will take care of drilling the slave...
Forgot to have you pick up four throttle body clamps from bentonville. They attach the air intake to the TB.
You'll need to remove the OEM and may not be able to re-use.
Just shipped off a big box of goodies. Few of which I want back, the remainder are gimmes.
Your in good hands I thought him well.
PS print out the two PDF's for reference...
Discussion Starter #15
PDF's printed and I've added throttle body clamps plus silicon radiator hoses
I have all the local add ons already plus some super expensive paste on the way.
That pipe / seal puller in picture #6 is genius : )
As Bartles & James used to say "Thank you for your support"
1 - 15 of 15 Posts
