Maintenance Schedules: My RT vs My Chevy
I am not complaining as I really like my new RT. I do all the regular service and find it sort of therapeutic -- it's cheaper than visiting a shrink.
Whenever I get a vehicle I list the Maintenance Schedule on a spreadsheet to remind me of what and when I need to do something. After reading a few interesting threads on maintenance schedules for the RT on this and another forum, I decided to compare my 2012 RT to my 2007 Corvette Z06.
1. FINAL DRIVE / DIFFERENTIAL:
BMW: final drive fluid changed at 6,000 miles then every 12,000 thereafter
Corvette: changing differential fluid not needed
2. VALVES:
BMW: adjust valves every 6,000 miles
Corvette: no valve adjustments, hydraulic actuation
3. SPARK PLUGS:
BMW: spark plugs changed every 12,000 miles
Corvette: spark plugs changed at 100,000 miles
4. THROTTLE:
BMW: sync throttles every 6,000 miles
Corvette: no synchronization needed, drive by wire
5. TRANSMISSION:
BMW: change transmission fluid at 6,000 miles then every 24,000 miles thereafter
Corvette: lifetime transmission fluid for manual transmission, automatic transmission fluid changed at 100,000 miles
6. BELTS:
BMW: replace alternator belt every 30,000 miles
Corvette: engine accessory drive belt inspected at 150,000 miles and replaced if showing wear
7. COOLANT:
BMW: no engine coolant
Corvette: change engine coolant at 150,000 miles
8. BRAKE FLUID:
BMW: brake fluid changed every 2 years
Corvette: no scheduled change
9. AIR CLEANER:
BMW: air cleaner changed every 12,000 miles
Corvette: changed every 50,000 miles but inspected earlier
10. WARRANTY
BMW: 3 year or 36,000 miles
Corvette: 3 year or 36,000 miles plus 5 years or 100,000 mile powertrain warranty
I'm not including all the numerous miscellaneous inspections for leaks, brake pads, loose nuts and bolts, etc, for both vehicles. Also, I'm using the normal duty cycle for the Vette, not severe duty.
Anyway, I find it an interesting comparison.
2. VALVES:
3. SPARK PLUGS:
4. THROTTLE:
5. TRANSMISSION:
6. BELTS:
7. COOLANT:
8. BRAKE FLUID:
9. AIR CLEANER:
10. WARRANTY
