I took the top case off for the improved handling for my daily drive to work but I put the luggage rack back on to give it a more finished look. I'm looking for a way to reconnect the brake light. I know the brake wires are yellow/gray and brown but the wires coming out of the luggage rack are purple and orange. Can I just connect those wires to the ones under the passenger seat? If so which is which?
Thanks in advance for the help, as well as the smart ass comments...
Hi, the easy way to do is connect the wires to the break light bulbs like I did.
Hope could help, Manfred
I'm just wondering what a wombat is doing so far from home living in Texas.... :wave
:histerica
Hope those fires are keeping away from you guys!
Just an FY and you probably already know this, but you can take the luggage rack apart and route the wires internally.
There is kind of a "waffle grid" inside, which can be easily cut with a Dremel tool and abrasive cutting disk to make more room for an extra wire run if needed.
