1 - 16 of 16 Posts
I just finished changing all the oils. Engine, Trans, Diff. for my 36K service, Used Mobil 1 all the way around, and when I went for a ride It seemed that the bike was significantly quieter. Mostly the trans upshifted much quieter. Is it possible the trans oil was low?
I didn't pull the fill plug until I had already pulled the drain so I can't verify that the trans was full. And I filled the trans till oil was running out and put the plug in with oil running out.
Or is it all just in my head <g>. Again....
Spence
Spence,
Similar experience here. I always hated the way my bike clunked on shifting...and I often missed shifts because the tranny was hard to shift.
I put Mobil 1 in and immediately it was smooth and much quiter. Has been like butter ever since. I was actually shocked at the magnitude of the difference.
I went from frustrated to happy!!
re: mobil 1 oil
Did you use synthetic oil al the way around? Did you use the recommended viscosity type recommended for each specific area?
Discussion Starter · #5 ·
Used 15W50 extended life for the engine and Used 75W90 in the trans/diff.
Both Full Synthetic.
Absolutely ! When I lubed the shift linkage at 12K it made the most difference of all of the maintenance I did. Very smooth. I just received some synthetic grease and will try it on the shift linkage next service to see if it makes a difference.
14mm Allen
Larry, get thee to Autozone! They have a 3 bit set which includes a 14mm for a very cheap price. This is where most of us on the list found ours.
Discussion Starter · #10 ·
Yepper., Autozone
7.99 for the three bits...
Can't go wrong. As long as you have a 1/2" drive wrench..
Spence
Careful the forum police will get you.
Discussion Starter · #15 ·
Hi Kip,
Please consider filling out your user profile so someone near you might be better able to help you than I.
Anyway, PepBoys, Autozone, Oreilley's, NAPA, and finally WALL-MART should all have mobile1.
IBR# 366
Yep, Mobil 1 is pretty standard at most auto parts places. And contrary to the excessive marketing hype, you do not need motorcycle-specific oil for the LT. It has a dry clutch, outside the engine oil bath, so it runs more like a car engine than a bike engine. Maybe a few more rpms, but standard oil works just fine if it meets BMW's recommended specs.
1 - 16 of 16 Posts
