1 - 2 of 2 Posts
I am trying to locate the connector where the BC switch from the RH multi-function cluster connects to a brown/black stripe wire that goes over to the OBC connector at pin 1. Looking at pictures of a RH switch module it looks like the wire from the BC switch exits the harness with the grip heater switch connnector at the front of the bike. Can anyone confirm that is where the BC switch connection is made?
thanks,
Ralph
Discussion Starter #2
After seeing a RH multi-function switch with the BC switch I could see the brown/black stripe wire goes into the electronics box in the main connector.
1 - 2 of 2 Posts
