1 - 3 of 3 Posts
Gents, I installed a new battery last week and finally got around to taking it out for a drive. Been kinda difficult between the snow and the rain we been having up here in the Great White North. I also installed an Eastern Beaver fuse block while I was at it. I started the bike and it idled for a couple of minutes and then stalled and wuldn't idle without using the throttle. I put it n charge over night and ditto. I then took it out ofr a 20 min ride and stalls every time I pull in the clutch. Would appreciate any thoughts your advice
Doug
Did you reset the throttle position sensor after you changed the battery?
Key On/Engine Off
Turn throttle to full open twice
Turn key off
Kevin
Kevin, it did the trick:) Thanks, I for one appreciate all of you guys advice and help on this site and have joined the club with a subscription.
Doug
1 - 3 of 3 Posts
