1 - 20 of 24 Posts
I have a HF lift. I have a chock on the front. The bike is on the lift right now sitting on both tires. I have lot's off maintenance to do. To flush the clutch system it says to turn handlebars all the way right. I can't do that with chock. Does anyone put their LT on the lift on centerstand. I can remove the chock but unsure about safety of putting it up on center stand.
Enjoy The Ride
I did mine on the lift the first two times but it was to scary. I now do it on the floor on the center stand & bungee cord the handle bars + tape plastic bags on the body. Also lay a razor blade on the bottom of the handle bar reservoirs so they don't spit any fluid out while your pumping the lever.
I have a HF 1000# lift and put mine on the center stand all the time. I understand the scary issue since I almost ran my LT off the front of the lift the very first time I put it on and lifted it all the way up. When I went to lower it down, my lift lurched a little bit and it was enough to "bounce" the bike off the center stand and it rolled forward, with the front tire rolling off the front. It hung up on the center stand guard and did not go all the way off. But boy did it scare the S#%& out of me! What I now do is put it on the center stand then turn around the front tire chock and slide it against the tire. That way the front tire is all the way against the front when on the center and can't roll forward. I have also put 3 additional rings on each side to strap the bike down. I've now had my lift for about 18 months and it's been up and down many times, always on the center stand. I never have thought about having it on the side stand, thinking that it would not be centered and have the weight leaning too far over.
Other than that it's a great lift at a better price. I love mine and can not imagine doing my work on the garage floor.
I do all my maintenance with the LT on the centerstand on a HF lift.
For everything except front wheel tire changes, I put the bike on the centerstand and then clamp the front tire with the lift's wheel clamp.
For front brake and clutch fluid changes I have found that I don't really have to turn the front end, nor to I have to rotate the perches to level the resevoirs as described in the service manual. I do use the razor blade trick to avoid the splashing and retrieve the razor blade with a clean magnetic retriever tool before the cover goes back on. I have found if I fill the resevoirs right up to just below the edge of the low side of the resevior and then carefully install the cover there is no spillage and when I am done the fluid level is close to the middle of the fluid indicator window on the resevoir. Doing it this way greatly simplifies the procedure and I've never had a problem with fluid levels.
A razor blade? Please explain. Thanks.
He uses a razor blade; I use a paper towel or the reservoir cover -- the issue is that when you release the lever during manual lever-pumping bleeding, the fluid returning to the reservoir from the master cylinder feed hole at the bottom of the reservoir *shoots!* straight upward like a fountain, resulting in brake fluid all over the tupperware and windshield. The razor blade diverts the "spurt."
On one of my LT's, during a warranty brake job, the tech let the fountain erupt, and permanently marked the right side fixed clear wing (they did offer to replace it).
Good night Dave...that looks like some sort of a perverted Gynecologist's office! Just what are you doing to that motorcycle??? :histerica
I have put many an LT on my lift using the LT's center stand and securing the bike by straps (properly placed) over the fork tubes, just above the front fender. never had any problems with stability yet. I just leave my front tire vise as wide open as it will go and the bars turn pretty well. The only time I use the straps from above is when I remove the center stand for a clutch replacement, etc. Just added security.
Thanks all, right now I have a HF chock that I bought extra on the lift. I will have to back the bike off some and remove the chock and put the vise back on. Good tip about the razor blade. I am also going to do the coolant change among other things.
Great idea. Thanks for the tip.
Minor point, but the box knife type razor blade works well.
I tried a double sided blade it it just shoots through the slot in the middle when it shifts around.
jim H.
me too, but I tend to remember longer when I have to do something twice....
Jim H.
Santa is bringing me a HF lift for Christmas. I was thinking about getting the chock too, but looks like a lot of the gurus don't use it ? Pros-Cons?
Super Moderator
This is not a hijack . . .
Who needs a wheel chock or a scissors lift - I use a bike lift and no problems:
1. Taking off both wheels at the same time!!
2. Servicing all the brakes
3. Working on most of the LT parts that require simple maintenance
4. Spark plugs
5. Setting the valves
6. Dropping all tupperware
To ensure safety torquing major of bolts "off and on" are done with the bike on the ground or just inches in the air.
Not sure I could perform a transmission drop or a clutch job - will cross that bridge when I get there . . .
Bad news is that you cannot change the oil but you can change the transmission fluid
and there is no table to drop parts and hold tools . . .
We now return to your normal listening channel!! :D
I too have a HF lift. After the first few uses I removed the chock completely. I decided if the big girl wants to tip off the lift the chock wasn't going to do anything to stop it, except maybe ruin the front wheel. I tie the bike down as if it was being trailered, and if I'm not changing the oil or front tire, secure the centerstand to the front wheel as extra protection against rolling forward and off the stand.
Hi Jack,
at the risk of being accused of a thread hijack I just wanted to be clear about one thing: do I need to remove the center stand for my clutch replacement or not?
You say here that you do but from what I can see on your pictures posted on your thread titled "Pictures Of My Clutch Teardown" I can see clearly that the center stand has not been removed. I'm about to start this major work in a week and I just wanted to be sure I start on the right path.
Eno
zuchero said:
Hi Jack,
Eno
I noticed and just wanted to say that the cup cake pan is a great idea for screws, etc... :)
Wonder what his SO will say when he tries to return it??? :rotf:
Enjoy The Ride
Well Jack all I can say is I'm sure being a Clergyman like you gets you to the hospitals and doctors office's much more than me and being I've never been to a gynecologist :histerica I'll just have to take your word for it. :D
I also put my bike on the centerstand all the time on my lift I just don't jack it up like that anymore.
Click on this website and you will see some things I did with my lift. Using it for an LT you do not need to do all of this. When I first got it I had an LT and used it with the front vise but this is much safer.
http://s453.photobucket.com/albums/qq256/2jerrym/?action=view&current=HarborFreightLift.flv
1 - 20 of 24 Posts
