You should not have a problem. There is a possibility that the pivot became loose but it has a lot of thread on it and it has limited room to "back out" so there should be no damage to the swing arm.
If it was damaged on removal I would like to know how they torqued it back in properly as it gets 160Nm or 118 FtLbs. If I remember right it was the right side and that one has a fixed bearing cup that gets torqued to 200Nm or 147 FtLb.
The left side has a floating bearing cup that gets a small pre-load of only 10Nm or about 88.5 inch lbs, then a back up ring that gets torqued to 160Nm. If any of there were not set right it could lead to your squeak.
Good luck wth the shop.
