It depends on your definition of “Easily”. I lowered the brake pedal on my 2019 RT. It required a bracket to relocate the rear master cylinder. There is no adjustment as there is on the shift lever.Can the brake pedal for the rear brake be easily lowered on a 2022 r1250rt?
Thanks. I decided to order the adjustable brake from Illium. I figured that was the easiest solution.It depends on your definition of “Easily”. I lowered the brake pedal on my 2019 RT. It required a bracket to relocate the rear master cylinder. There is no adjustment as there is on the shift lever.
This is the route that I went. It works well, although the brake pedal is a little longer.Thanks. I decided to order the adjustable brake from Illium. I figured that was the easiest solution.
Yes, I wish the brake could be adjusted like the shifter can.This is the route that I went. It works well, although the brake pedal is a little longer.
I was able to just adjusted the shifter with no replacement parts needed.
I adjusted the rear brake lever on my 2019 1250, it’s very fiddly but does adjust.Yes, I wish the brake could be adjusted like the shifter can.
