pozo_izquierdo said:
Curtis, I'm just curious...why you don't want to use a trailer hitch? Especially Dauntless' design is ideal for the luggage rack. I can remove or install my rack in two minutes (including the diagonal support cables) and without the rack there are only the round tube ends visible in the rear of the bike.
The bike side parts of Dauntless are well proven and tested. Into the tubes you can design your own rack just as Toolman had done. In my project I used more Dauntless parts since my rack is fastened into the hitch receiver but this was only because I happened to have the Dauntless set available.
Regards
Actually, I have been looking into the Dauntless. I'm not really interested in pulling a trailer and the other "better" trailer hitch is way over the top for me. I don't want to look at it, and I don't want to have to remove it to change a tire.
I'm temped to weld up a frame to make a rear luggage rack but if I could obtain a Dauntless and save myself the fabrication time and materials costs, the Dauntless would work for me.
I've been putting 20lbs of bulky camping gear on the topcase rack, and moving it down low seems like a good idea. When I first started reading this thread, I thought maybe someone had fabricated a race without a trailer hitch. Now I realize it probably isn't so.
Still learning and mulling the options here. Thanks!
