I have photos, but can't seem to get them to imbed in this forum.
The first wires, seem to come from my fog lamps on the tires. One wire has a 20amp fuse and the other 3 wires go into, what I would guess is a type of Switch/solenoid.
The other major loose wire is black wire with a red shirnk tube on it, after about 4" it goes into a gray plastic box.
Hopefully someone can assist me on uploading some photos, or give me info on my basic descriptions.
click on manage attachments under the message box then select the pic to upload
Other info, the loose wire from 2nd photo (the one with the gray box) shorts out when it touches the positive battery pole. I learned this 'cause I was listening to the radio while working on the bike, touch it the battery (Yeah, yeah I hear ya'll doing the face palm slap! :histerica ) and sparks flew and the radio turned off and reset.
My .02 cents...
Do you have a CB in your oddments box?
I have a similar wire that is for the CB.
I hope this helps.
Yes, I have a Midland CB in the Glove box. And two antennas, but the CB doesn't come on.
I guess buying a '03 K1200lt custom over the internet a 1000+ miles away has it's down sides.
I bet if you put the cable to the battery and looked at the CB, the CB radio would power up..
