+1. I've usually gotten it off with a stout tug.kevincook said:Remove the right plate holding the passenger foot peg. you should be able to put the tip of a large screwdriver inside the u-joint and on the end of the transmission shaft and pry the shaft off. It should come off pretty easily.
Check the instructions in my signature.
Kevin
Or hit it with a hammer! lolhallzee said:+1. I've usually gotten it off with a stout tug.
