About 6 months ago I replaced my OEM battery with a Shoria Lithium Iron battery. Since these batteries are rated to hold a charge for reasonable periods I did not buy the associated charger. While I don't ride as much as I used to I still manage a minimum of a couple of hundred miles weekly and the battery has performed as advertised. Unfortunately over the last 4 weeks I have been unable to ride and the bike sat idle. Anticipating a ride this weekend on Fri I checked out the bike and the battery was unresponsive. With it still connected to the bike I measured the voltage and it showed a measly 2 volts! Having read all the negatives about using a standard charger on these batteries I was concerned but threw caution to the wind and tried my regulated trickle charger with no response. I then broke out the 12v/2amp charger and connected it. After about 20 minutes the current dropped to near 0 so I disconnected the charger and measured the voltage again. This time it was 13.25 volts and 2 days later it's still showing a full charge. Seems like the battery just went to sleep due to sitting idle and it took a kick in the ass to wake it up. Can anyone tell me why this would happen?
Every modern motorcycle has some rate of parasitic draw.
When battery manufacturers claim that their batteries will hold a charge for extended times I'm sure they are referring to on the bench not connected to the vehicle. I have a Honda car that I don't drive often. The battery will draw down as much as 5 or 6 volts in about a month or so if I don't drive it or keep it on a trickle charger.
I have a automotive battery from 2012. It was in my BMW 318 until it was wrecked a year later. This battery sits on the floor in my garage not connected to anything. It holds a 12 volt charge for several months. I load test it about once a year or longer. It still passes the test. When I hook up a charger to it from time to time it will fully charge in under an hour.
If you are curious about the battery drawing down after a month and have the ability to check parasitic draw then give it a shot.
My other suggestion is ride more often. That's why we buy these expensive ultimate riding machines.
Thanks for the feedback Bob. Yea I'm well aware of the parasitic draw that occurs with any modern vehicle. I also wish I could ride more often and further unfortunately sometimes health and family have priority. I am still curious as to what caused my battery to hibernate, measuring only 2 volts, until I hit it with an external 12 volts and around 4 or 5 amps for a short time. That jolt seemed to work like a defibrillator and restore the battery to full function?
From what I have read about them, they are supposed to last a long time sitting idle. I do not have one but was thinking about it for my next battery.
