1 - 3 of 3 Posts
tore my bike down again tonight to try and solve my problems ie flashing headlight at high revs indicators still working after turning ignition off .abs keep flashing when riding .,
what i did find was when i turn mu bike on and press the indicators they fash and keep flashing when i turn the ign off put when i lightly tap the ecu they go off as they should and the bike is no longer live so i think i need a new ecu if i try and unplug mine and plug it back in will i have to have it reset
Just unplug it and open it up to look for moisture intrusion. If it is dry you can just plug it back in and everything will be as it was. No resets necessary. If it is shot then look at wrecked bikes for a source but you must match the PN on the ECU.
Reactions: djmellor
Discussion Starter · #3 ·
turns out t is my flasher relay staying shut creating a circuit i have replaced it and fingers crossed it works but but not rebuilt bike yet
1 - 3 of 3 Posts
