VDale420 said:
Is it a coincidence that all of you complaining about battery life are using a battery tender?
My fear is that the tender boils the battery dry. That kills batteries as quickly as anything. I wonder how many of those dead batteries would comeback to life with a little water.
I keep my terminal connections clean and do not use a trickle charger on my Honda. I think the current battery is 6 years old. I haven't had my 2002 R1150RT long enough but when I took delivery the battery was dead and the prior owner used a tender. The terminal connections were really corroded. He also had a CB and Satellite Radio and not sure what else. I not sure what their amp usage is. If you are using more amps than the alternator makes, I suggest you need a bigger alternator or some power management decisions, not a better battery.
My 2¢ Dale
Funny that you should quote me, and I don't have any battery issue!!!
In any case, I think that your evaluation about a good modern trickle charger boiling off electrolyte is a misunderstanding (or misinformation) on your part. Your statement might have been either true or very close to the truth once upon a time, but not any more!
These modern chargers are very intelligent in that they senses the voltage of the battery and apply a charge voltage only when the battery voltage drops below a certain level, otherwise no charging is applied. The charger that I use is "Battery Doc", and when I have it connected directly to the battery, I would rarely see the charge light come on at all. That made sense to me, because with the direct connection the CAN Bus is turned off, and the only draw from the battery is the bike's clock and other very minor electronics. OTOH, when I have my charger connected via the external power port on the RT, the CAN Bus stayed active all the time, and there is a bigger draw on the battery from the CAN Bus. As a result, I would see the charge light on the charger come on every few hours, but for less than a minute, just to top up the battery.
