1 - 13 of 13 Posts
I just got back from a 1,400 mile ride to the black hills. It was absolutely wonderful, but of course I noticed new and exciting things to ask about the LT while I was there.
1. It seemed to me that the clutch was noisy from 3,000 to about 3,200 RPM's. What is the cruising RPM's everyone rides with here? Is this a possible clutch problem? The noise sounds like the throw out bearing in a car when it runs a too low of an RPM (hence the question).
2. What mileage did people see from their Stock tires? I have about 5,000 in 2.5 months right now, and they are starting to look a bit worn.
3. I noticed a distinct lack of luggage space on the bike. I know I can remove the trunk, but my wife would be awful angry if the heated seats went away. :) Are there any suggestions as to a good tank bag? Should I just get the BMW bag?
Thanks as always. Your help is appreciated.
My clutch sort of rattles like there is not enough pressure or a bearing is bad. It only happens below 3200 RPM's though. I know it is the clutch because:
1. When I rev the bike in neutral up to 3k RPM I do not hear it.
2. When I pull in the Clutch while it is occurring I do not hear it.
Based on further research here it looks like the fix is to ride at higher RPM's and forget about it.:)
But, I hate to be less than thorough.
Not likely clutch, as there is nothing to make noise if the clutch is engaged. The "throw out" bearing is a very small bearing in the end of the slave cylinder piston, less than half inch diameter. You are probably hearing exhaust system vibrations.
This is highly variable, depending on how one rides, which tires, road surfaces, bike loading, etc. I think the AVERAGE is about 10,000 miles. I got about 8-9,000 front/12-14,000 rear on BT020 radials. Metzelers get better front mileage, but did not suit me for other reasons.
I liked the Chicane bag made especially for the LT far better than any other available option. Marsee also makes a nice one, but do not make one specially fitted to mount to the oddments box lid, you have to improvise a little. I did not like the RKA one I had before getting the Chicane, and the BMW one is too small for me.
The Kathy rack bag has helped me a lot when my wife rode with me on trips. I could move lighter items like rain gear lite clothing and bike cover to the rack bag to make room for curling irons (2), blow dryer, makeup, more makeup, shoes (several pair), lighted makeup mirror and on and on.
Around $100.00 - I think - its been a couple of years. Seems to be well made and water proof.
I have the ZTechnic rack on my top case and the previous owner gave me the Magsbags carrier that fits it. It's great. :D Plenty of extra room, expandable,velcros onto the rack really securely and has a raincover included. Take a look at them on their website: http://www.magsbags.com.
space bags work great for adding a lot of extra clothes,,,42 psi in the front 48 psi in the rear you should get 15-20,000 miles out of a set of tires all loaded up, cruise along all day at 75 mph
I'm a new rider and I'm wondering the same thing. RPM shift points, etc?
The LT really does not like anything below 3000, except when just cruising along at low throttle settings in fuel saving mode.
If you are past the first 600 miles or so, try keeping it above 3000, or even 3500, shifting at around 5000 if just riding around, 7000 plus if in the twisties having fun.
You will find pretty quickly that this fat lady loves to sing!
The biggest mistake for people coming from big V-twins is shifting WAY too early, wasting most of the powerband of the K engine. It just starts to get happy around 4000!
rpm
3500 or above....................
Dave,
I think your right about the exhaust noise. I was messing around today trying all this stuff out and of course it helped some. The bike was definitely happier with the RPM's up around 3500. It also seemed the clutch was holding pretty well.
How would I track down the exhaust noise? Do I need to pull the tupperware, or is there a usual culprit to this issue?
I really love this bike but man that noise is annoying.
Thanks for all the help.
Just head down this way, and we can take a look! (for the noise that is..)
Thank you very much. You nailed it on the head for me. Afraid I was going to tear the thing up. Onward to higher revs I go!
1 - 13 of 13 Posts
