1 - 11 of 11 Posts
Hi all,
What tool best accesses the torx screw for removal/install of the left side lift handle? It's tight access and I don't have the greatest selection of tools, but will acquire what's needed. I want to remove the ABS for refurbishment and upgrade to Speigler ( on hand ) brake lines.
Jer
Hi all,
Jer
Yeah, that fastener is a pita. I used an Allen (hex) wrench, 1/6 of a turn at a time. Once loosened, I was able to use a ball end Allen wrench. But even with the ball end wrench it was slow going.
I have a craftsman set that looks like these:
26 pc. Standard and Metric Key Set: Get the Grip You Need with Sears
I don't have anything like this, but I wonder if the hex bit in the little ratchet would be small enough to fit:
http://www.mscdirect.com/product/details/05045018?CS_010=05045018&item=05045018&CS_003=7867724&src=pla&cid=PLA-Google-PLA+-+Test
Using a bit ratchet like that in above link with a shortened hex bit would do the trick I suspect.
I use a Allen ball driver. I have not seen one that was Torx. 5 mm IIRC
Discussion Starter #4 (Edited)
Wow! Thanks Curtis & John. Ball end driver it is. Like I said, my tool selection isn't extensive, but building over the years. Looks tight for the hex bit in the little ratchet. Though, I really like the idea.
Have fun,
Jer
Thanks Dave, and thanks to you and Lee for giving me the 411 on brake lines.
Jer
If you can get the ABS unit out with only removing the lift handle, you are a better man than I. I had to tear down to practically nothing and remove the back up controller, and you'll need more than a ball end Allen Wrench (although a set of those will go a long way on this bike).
Just for my own information, what is a lift handle? I have torn my bike apart replacing the clutch and I don't know what you consider a lift handle. The only handle I use is the one on the bags to pick it up when it takes a nap!
The handle under your left cheek. :)
Have fun,
Jer
Just getting started. I'm sure I'll run into more issues and need more tools. Good start, though.
Jer
I assume the lift handle isn't on the newer LTs with the hydraulic center stand... That one threw me too, until I saw that the guys talking about them had '04's and older bikes. :corn:
1 - 11 of 11 Posts
