1 - 20 of 21 Posts
Need tech input for adding a "bright" LED brake lite to the back of my '05 K/LT. Been told, "warned", that adding such other stuff, might upset the signal integrated into the ABS. I don't have a clue and looking for who knows.
Just don't want to get clobbered in the rain and fog.
Senior Member (ret.)
Based on your question, I assume you do not have the top rack on the top box.
Open your top case, remove the screws that hold the mirror and storage in place. There should be two wires that are stubbed out there and these are used for connecting the top rack integrated LED light bar.
For an aftermarket LED light bar, you may have to change the connectors on either side and you are done.
If you want to make your LED light bar a decelerating pattern flashing brake light (4-3-2-solid), there are two products:
Kisan tailBlazer - this makes the LED light bar a running light at half power and a flashing brake light. www.kisantech.com
Rider West - Brake Flasher decelerating pattern, without running light. www.riderwest.com
They both go inline between the existing wires and the LED light bar. The Kisan is made for the top rack OEM LED light bar. The Rider West necessitates cutting the stock connector off and using bullet connectors - that is, it should work with most aftermarket LED light bars by cutting the two wire connectors off on each side.
LED light bars are available from:
www.signaldynamics.com
and I am sure several other places.
Hope this helps.
Never pay again for live sex! | Hot girls doing naughty stuff for free! | Chat for free!
As long as you stay away from the circuit that feeds the center running light you will be OK. That is the only circuit that is monitored by the ABS. The two brake/running lights on either side are not monitored.As Raffy said the pigtail in the top case is also a good place to get the brake signal, I used it for a home made brake/running light that is attached to the top of the top case at the backrest.
2011 R1200RT
I bought from a member in this site a Brake! unit designed for the LT and installed it on my 05. It is programable, and does not affect the ABS system. I get a lot of comments on how bright my tail light is and how much attention I get when I hit the brakes.
http://www.homebody-design.com/catalog/brake/brake.html
The product is manufactured in Canada.
During installation I found that I had to sand paper the openings for the bulbs as they are a tad larger than stock (took all of 5 minutes).
That looks like the units my dealer was demoing when I bought my bike. I liked it so much I had him replace all three brake lights. Now when I hit the brakes it looks like my rear end exploded. A number of people have commented on how attention getting it is.
Bruce
BRAKE! LED Replacement Tail Light/Brake Light
Replaced the factory lights with the BRAKE! LED Replacement Tail Light/Brake Light.
Bought mine at BMW-Ducati-Triumph of Charlotte (NC).
Also saw them at Capitol BMW (Raleigh, NC) Morton's (VA) and Bob's BMW (MD).
Five minutes to install.
Snaps in, replacing the stock bulbs.
Below is the link to the light at Sierra BMW (NV).
http://www.sierrabmw.bigstep.com/item.jhtml?UCIDs=820323|820415&PRID=1547491
Big difference.
Pulsates (slow or fast, your choice), then glows steady.
I have to agree. I purchased the same setup at the BMWMOA Rally.
It has an adjustable time for the blinking of the brake lite. ! sec, 1.5 sec, 2 sec or off - no blinking at all.
In order to provide the benefit of brighter tail lights and much brighter brake lights, I designed P3 Lights. They allow you to keep your stock tail light intact and so avoid any CAN-bus issues. The additonal lights also give you a larger lit area and, as well as redundancy.
They are fully K1200LT compatible. Click on the photo for more details.
+1 on the P3. I bought a set at the CCR silent auction and put them on my wife's Burgman. They also have a running light feature that flickers the led's at high speed, and it's an attention grabber.
Because of my irrational fear of being hit from behind, the first 'farkle' I purchased for my bike was the Kisan Tail light modulator - from Raffy's company - which I recommend highly for his service. I think just about every LT Rider here that saw it purchased one too. I also think it is one of the best dollar for safety values available for the LT - mostly because of the placement of the LED light bar on the trunk. As a safety / value thing, this is only slightly better than the $.35 John Rehder center rear brake light activation - which he did on my bike at a service session long ago.
John said:
"+1 on the P3. I bought a set at the CCR silent auction and put them on my wife's Burgman. They also have a running light feature that flickers the led's at high speed, and it's an attention grabber."
Glad you like the P3 Lights, John. I was curious about who the winning bidder at CCR was.
I had been looking for something for her Burgie for a while, and when I saw the P3 system I knew that was it. I put my bid at the retail price to give myself a good chance of winning. Thanks for your donation for the kids!
Has anyone installed a set of these P3 lights on their LT? I just bought a set and was hoping someone had already installed then and could give me some pointers. Any info would be appreciated. Thanks........
Bill
A few weeks ago, I put the Kisan Tailblazer on my 04LT. It has the existing LED bar as a running light and then flashes when the brake is applied. I think it is great because I didn't have to add anymore LED's. At the same time I added the Kisan modulating headlight. I have a larger concern of someone turning infront of me than being hit in the rear.
I did the Brake! LED kit too, the problem is that right now they are in short supply. So, they can be hard to find. E-Bay had one or two recently, but they wanted $50 more than I paid for them.
The nice thing about them is that they are three seperate bulbs. Center and two satallite bulbs. They really do a nice job. Better than anything else I have seen on the market bar none.
I just put a set of the Brake! led lights on my '05 - they're great! I bought them at the BMWMOA rally over the weekend from Santa Cruz BMW - they have them on a closeout. If you order them make sure to ask for a set with the resistor on the master module - you'll need it on your '05!! (I tried the "regular" set and had a taillight fault appear and the resistor type works perfectly). They worked so well and were such at such a great price my buddy bought a set for his '05LT too!!!
1 - 20 of 21 Posts
