1 - 2 of 2 Posts
I have same leak others have identified on the 03. It is at the base near the front of the unit. It's a substantial leak. I am not getting a flashing brake warning light as long as I keep the reservoir filled and the brakes seem to work fine.
Has anybody ever located the cause of this leak?
Is the only option to replace the unit? (major $$$$)?
Any suggestions?
Looks like I have the same leak. Degreased that area last night and can now see a slight seepage around the front base of the ABS unit :(
Is the the only solution to replace the ABS modulator with a new/used unit?
'02 K1200LT
St. Augustine, FL
1 - 2 of 2 Posts
