1 - 3 of 3 Posts
My wife finally settled on a K75 last year (instead of the K1100LT). She took it out for a ride earlier this week and I noticed a leak (front right) looks like under the radiator. It's blue fluid... not much of a leak but I can't see where the leak is coming from. Any ideas what it might be?
Most likely it is coming from the weep hole under the water/oil pump. It was designed that way and may not be a problem for some time to come. A lot of the time it will quit and not reoccur for a long time. If it continues to be annoying, then you need to have the water/oil pump seals replaced. Not too big a deal.
Discussion Starter · #3 ·
Thanks for the quick reply.
1 - 3 of 3 Posts
