Various reasons , but ultimately it boils down to the total weight ,and what the tires and suspension is rated for .
I looked into this before
RT per the manual is
259kg (570lbs) unladen with fuel at 90%
495kg (1091lbs) Max vehicle weight
Payload ie everything else 236kg (520lbs)
K1600GT
319kg (703lbs)unladen
540kg (1190lbs)Max vehicle
Payload 22kg (487lbs)
Tire size base on Michelin Road pilot 2
Front tires for both are 58W which is good for 236kg at 270km hr
Rear tire RT 73W which is 365 at 270 km hr
Rear tire GT 75W which is 387kg at 270 km hr
According to that say 601 (1324lbs) and 628 (1373lbs)
There seems to be a bit of leeway on the RT , not as much on the GT, and assuming you are doing 270km an hour,say 167 mph
You should look at the rating for a Honda st1300
Snivly
