Hi,
I bought 1999 K1200 LT with rear drive from latest model installed. There is no speedo sensor housing on it.
Does any body know the way to make a speedometer alive?
Thanks :confused:
Unfortunately, yes: Put the correct series Rear Drive unit on the Bike. The newer ones did not use the same type of pick-up as the older ones did.
Unless someone else knows how to do some sort of mod, I'm afraid you need to replace the unit. Maybe someone here is in need of a spare drive?
Since the speedos are, by design, inaccurate, they read about 10% high, a few people bought Garmin GPS, and used the speedo built into them. (Good excuse to buy a FUN toy)
That year came with a defective starter relay; if your battery goes dead, or almost dead, when you try the starter the relay fuses closed.
Bob, 00LT
You could try one of the K1200lt trike builders. They may swap you a '99 drive for your newer drive. They are a good source of rear drives if you want to buy 2nd hand
What bob said:
for what it would cost you (to do it yourself) and replace the final drive, even used.
you could get a nice GPS.
I never look at my speedometer, GPS is more accurate.
could try www.cyclesrecycled.com for a correct year drive for your bike, might be able to work out some kind of a swap, who knows.
