I received a call today from Bridgestone Motorcycle tires engineering in Nashville, TN. We talked for about ten minutes discussing my BT020 rear tire failure. I will be sending the sectioned tire to them for further analysis. Hopefully something will come of this effort. If you have had any failures on your K1200LT using the Bridgestone BT020R 160/70R-17 tire, now would be the time to post your findings. The more data we can produce and document the better chances we have finding the root cause of this type of failure. I’ll keep you updated or the results.
CLICK HERE TO TAKE THE SURVEY
Links:
Bridgestone BT020R 160/70R-17 tire failure web page.
http://pulsefl.0catch.com/bt020r/
Links:
