Help -I am newbie here.
Last week or so, I wanted to ride. Bike won't start, I then jumped from my car that was running. I know - NOW -that was a mistake.
I got the bike started from the jump. I turned it off to get something out of the back trunk,
Tried to start again, with the car..... No start at all - BUT the HORN is on continually.
I called and talked to a tech at the local dealership, he said replace the horn relay. The dealer didn't have a replacement.
I ordered one online and I have it in my hand. The question now is.... Which of the 5 relays under the gas tank is the horn relay??? I have it al apart.
Any ideas about what I need to try next???
I want ride......
I want ride......
When you fold out the relay holder, you should see 5 units lined up left to right. The horn relay is the 2nd from the left in the front row. The big unit at the right end is the flasher module - just for reference. Good luck. And if the horn relay isn't the problem, I'd follow JZeiler's advice and check grounds, etc.
Thanks, but I have a total of six relays
Top left one is green under that is a black relay
Then to the right is a top and bottom black relay
Then the third row is a top and bottom black relay
Three rows of two each.
Which one do you say is the horn relay???
I see the large relay on the far right
EricT
Look at the wires leading to the relays. The horn relay has red, black , green and green/blue wires going to it. OOps my bad that is the load relief relay the horn relay has red/white, Green, Brown/Yellow and Green/Gray
