Hello Everybody
I just got a this k1200LT 06 from second hand and I asked my BMW dealer to
help me with the alarm system using the remote. They made it work but somehow they
don't know how to use it and they told me to read the manual. I don't have the manual because this is a second hand bike and the previous owner did not included it.
Can any of you explain me how it works, so far I know that left button locks everything and right button unlocks, but that is old I know.
Thank you in advance
Ralph. :)
Press the ribbed (left ) button once to operate (close) the locks. Press it again to set the alarm. The right button deactivates the alarm and unlocks with one press. You may have to wave the keyfob in the genaral area of the seat to get the desired result as it does not work from a great distance. You may also want to check the battery in the keyfob for strength.
Hope this helps...
Mugz
I recently had some work done by the dealer. When I picked up the bike the alarm had been deactivated. I had to read the manual and try the procedure about 5x before I got it reprogrammed the way I wanted it. On my '05 there are a number of options you can choose when reprogramming it like audible alarms, lights, etc. The reprogramming involves turning the ignition on and off and pressing the buttons in a particular sequence. If you get stuck send me a pm and I'll try and help you out since I have the original manual, assuming your '06 works the same as my '05. BOL :rotf: cdrprn
'05 LT Goldfinger
No answers here but 2 days ago My friend & I were north of Yellowstone about 50 miles, we stopped at a rest stop for a little break, he left his key fob in the tank glove box, kept the key in his pocket, when he came back the security had activated itself, Even tho he had his key in hand he couldnt start the bike or open the door, we called a HD dealer we knew he looked up some BMW dealers in California, since it was around 6 where we were, Finally we got one
whose advice was pry it open, fortunately my bike was setting next to his so we could see how the lock worked, it came open pretty easy, but I quit keeping my extra fob in the glove box, It was kind of a bizarre thing to happen
