I have done some crazy stuff between the plane and the ground, but this....
http://www.flixxy.com:80/airplane-to-airplane-skydive.htm
You have to use a drogue chute, point a Cessna at the ground, even with the engine off, and it will rapidly accellerate way beyond the max test speed, and start tearing things off it. Like wings.bowlesj said:Man, that's cheating using that drogue
Still, a very cool stunt though. Thanks for the link.
No, don't point it at the ground, fly it along at stall speed and let him try and get in. Then you've really done somethingdshealey said:You have to use a drogue chute, point a Cessna at the ground, even with the engine off, and it will rapidly accellerate way beyond the max test speed, and start tearing things off it. Like wings.
This stunt is not new, I have seen it done on TV at least three times in the past several years. First time I think it was in Europe, and a Pilatus plane was used. Still a rather crazy thing to do though. Miss, and go into that windmilling prop..........................................!
Yeah, that would be something alright, even if almost impossible. A skydiver with the most drag he can accomplish will still be falling at a prodigious rate, and could not get into a plane, as he would slash by it like a falling brick. And with a Cessna, the wing would be in the way of the door. You cannot get a plane to go down at a relatively matching rate without nosing it down. It has to be falling like the skydiver.bowlesj said:No, don't point it at the ground, fly it along at stall speed and let him try and get in. Then you've really done something
Did you ever see that guy chute into a moving convertible? He gets beat up pretty good on a few tries.
Terminal is something around 120, but that is with legs and arms tucked back, head down and diving like a bullet. Loose clothing fluttering will slow it down a little. I think a skydiver with legs arms out and parallel to the ground can get it down to around 80. Can a skydiver chip in here?bowlesj said:I forget, what's terminal 120MPH?
