1 - 3 of 3 Posts
I have started to have a problem with my jpegs. When I make a turn to the left, for now, my jpeg comes out about 1/2 to 3/4 the way. Has anyone else experienced this problem. Is there a ball tint that has worn or what?
BMW Guru
There is a ball bearing that holds it in place. Is it still there??
Check two things
Take the J-Peg off and check to see if the steel ball and spring is there. If it is then it probably needs a little lube so the ball will compress the spring when the J-Peg moves. Sounds like your ball isn't being pushed back down by the spring which should hold your J-Peg in either clear out or clear in position.
Just my experience with the problem. A little cable lube fixed mine.
1 - 3 of 3 Posts
