Hi guys, I´m a quite new member in this forum and fairly new owner of a LT. My LT is from 2004, i.e the same as the US 2005 year model. My issue is that I can´t adjust the volume higher, only lower. Furthermore, the mute button is not functional at all. I have tried to use the buttons for both driver and the pillion but with the same result.
The highly recommended method disconnecting the battery I have tried several times without no change in the ability to adjust the volume. I finally asked a BMW mechanics to carry out a troubleshooting and he came up with the answer; the radio is broken. OK, so I got a brand new radio from the dealer that I bought the LT from (Long story behind that
) and installed it. The result? No change in the radio volyme settings; the problem was still there. I therefore opened each connection and had them cleaned with no luck at all. I do not think the problem is the buttons for the driver and pillion but in a connection somewhere.
So, have any of you encountered this problem? And in that case what was the solution?
Regards
Jan
Regards
Jan
