1 - 20 of 25 Posts
I am pretty sure that I have a main seal failure on my 01 LT (94K miles). See attached photos. The clutch slips under acceleration (per passing a car) but not under my normal riding conditions - I guess I am pretty conservative.
Oil consumption is not outrageous, about a quart every 1,000 miles. But now I am getting an oil drip on the floor, dropping down from the front left bolt holding the skip plate in place.
I haven't done a clutch before but have the shop manual, Clymers, Kenny Crawford's writeup on changing the main seal and Kevin Cooke's writeup on drilling the weep hole (plus John Zeiler's video) for removing the rear end stuff, plus loads of other information from Dave Shealey, Pastor Jack, etc on this website. So I think I will be OK on the seal changeout.
Would appreciate any thoughts.
It does look like it to me, but it's hard to tell. When mine started to leak, it was only a couple of drops at a time, so you'd never notice it on the oil level. Identifying the leak was easy, as there really was no other place it could have come from.
Sorry to hear it, but the job really isn't that bad. I actually enjoyed working on the bike.
In addition to the main seal there is an o-ring on the output shaft that gets hard with age and leaks also.
Dan...its time to dive into the belly of da beast! PM sent with links to tech files, pics, and parts listing from our 13 March Tech Session.
For what its worth.....yours looks past due for the repair! FYI....plan on ~15-24 hours of labor if you take your time and have all the parts on hand per the links I sent you. If you use the manuals and have all the right tools it should go relatively smoothly....even more so if you (or a riding buddy) are mechanically inclined.....Channing (cfell) was elbow deep with me and twelve other buddies were present when we dove into "Belle." In hindsight, it was probably the best thing I (we) could have done....I learned a tremendous amount about the bike (raised my confidence level in doing it myself) and it saved me about $1,000-$1,500 in labor!!!
Good luck! :bmw:
for others who may be in the same situation, here are the links for your quick reference:
Here's the link to the 13 March Tech Session
Here is a link to all the pics I stored on Picassa ....
here is the link to the complete parts listing with images from the fische.
and here is a price comparison for the parts you may consider purchasing.
The O-Ring will contaminate the clutch long before the main seal due to its location. Main seal is behind the clutch pressure plate housing and the O-ring is around the output shaft so when it leaks the oil runs right onto the clutch plate.
Roy
100 % YES.... The Oring is the problem, Be sure to replace with a Viton Oring..
UPDATE
Thanks to all who responded on this thread. Wanted to update everybody.
Put the LT up on the lift, and after three days got it "stripped" down to the clutch.
(1) Found oil in the swing arm which I conclude is from a leaking pinion seal (since there was no oil close to the transmission end of the swing arm). So I plan to replace that seal.
(2) Found fluid in the slave cylinder chamber. I assume this is a leaking slave cylinder, so I plan to replace that. Drilled the weep hole. Will replace the oil seal here as well.
(3) Found oil in the intermediate housing, so I will replace the main seal and o-ring. And of course the clutch.
(4) QUESTION - Both seals on the transmission (front and rear drive) were bone dry. Dare I NOT replace them (bike is an 01LT with 94K)?
I included pictures below for each of the areas addressed above. Hope they come through.
Thanks in advance for your thoughts.
Dan,
In response to Q4.....I would recommend you go ahead and do the seals (for ~$30 total)....you're already there and it will give you the higher degree of confidence your seals are good when you put Humpty back together again! Then again, if you know your oil is good in your tranny and there's no indication of leaks, you may go for quite a while longer. I know if I ever venture into the bowels of the bike again, I do plan on doing the tranny and FD just to make sure its all good to go.
Good luck and great job taking the plunge......make sure you take the hex nut (#8 in the pic)
it holds your clutch in place.....wire it up to the back of the bike next to your mini-good luck bell to show you've been there and done that! Its a boastful thing and creates better conversation than those sacks hangin' from some folks' pickup trucks! :cool:
Kenny
For me? I thought it was worth every minute....er hour....all 17 of 'em that it took to do the job and put it back together during our tech session.
Products from the session
Tech sessions are a great way to go....you learn a lot, make some new riding friends, and get to know your bike very well.....strongly recommend them if you do all the right homework and have the parts ahead of time.
:bmw:
BlauBeeMr said:
Dan,
Kenny
+ 1--your replacing everything else...what's two more seals? Great job by the way.
You may as well drill the weep hole in the bell housing while you're in there.
+1 on the seals as the brake fluid will destroy the rear input shaft seal. Best to have fresh.
I would not bother with the FD pinion seal as it is a bear to do. Need a special tool to get the sealing ring out and the nut is a 36 mm and on with 200 Nm of torque. Then the ring has to go back in with some special sealant.
Discussion Starter #15
Wanted to update everybody on my 01LT disassembly for replacement of the main seal and rebuild of the cylinder head.
See photos at http://picasaweb.google.com/sully2028/01LTDisassembly#
Am awaiting parts from Chicago BMW; should be here this week. Then the reassembly starts. I have my mechanic (of 15 years) helping in replacement of some of the seals.
Great pictures Dan. The hone marks in the cylinders was done at the factory prior to the application of the NaciSil (sp) coating. It will never wear out, just the rings. Did you find any fractured ring lands on the piston? The last one I tore down had them on all four pistons only one of them got so bad it took out the coating in the cylinder wall.
Sully2028, can you do me a favour, I have the 'bash plate' for the underside and can see where it fits to the oil sump, can you tell me where it fits on the rear, picture would be good :thumb:
Sully , change that dam input seal on the trans please,, because..
Why did you have to pull the head if power and mpg was good? Did I miss something ,Was it a smoker ?
I have the input seal install tool , you are welcome to it
Discussion Starter #19 (Edited)
Pete,
Will do! I have a high regard for your opinion. But pray tell, why is the tranny input seal changeout so important.
Guess I should also do the tranny output seal as well. That would complete all seal replacements, as recommended by Shealey and so many others on this site. Do u agree that is important?
I pulled the head because of oil being puffed out the exhaust and low compression in cylinder #2. Normally, I would have just lived with the oil consumption as it was within normal usage (1 quart per 1000 miles). But I figured since I was in there with the clutch, might as well do everything. Am getting some kind of blowby on cylinder #2 as well (see pictures of throttle body and piston) so I am replacing the intake and exhaust valve stem seals. Sixteen in total.
Am contemplating a replacement of the pistons, since these have 94K on them. I have a set of four from a wrecked 01 LT that had only 9K miles. But I am unsure about replacing all four since I have good compression (measured 195 psi) on three of them. Maybe I should only replace the piston in cylinder #2.
Thanks again!
Oil in #2 TB seems to be the norm from what I have seen onseveral bikes. The rings are the wear item so as long as the ring lands are not cracked just install new rings all around. Look really good as the last one I tore down had cracks on all four pistons on the second ring lands. Cylinder walls should still look brand new.
1 - 20 of 25 Posts
