Basically they are routed in parallel with the opener (Green Mark) cable to the outside. There are clips to hold them on the fan shroud. Make a smooth loop with the opener cable going down to the under side of the fuel rail. Up at the head of the teering they should flow down through the hole in the disc following the bars and pass ahead of the shock but behind the left fork.
