For those of you with these interfaces, can you answer a few questions about how it works and how you installed it?
When the iPod/iPhone is plugged in, does the display give you any useful info, or does it go into the "accessory connected" display with nothing else?
Can you do anything on the device, such as press the voice control button, or make calls if it's an iPhone?
Anyone mounted one of these up front, instead of in the bag? Is there an easy way to wire that in or do you run a cable all the way to the bag? Is the interface cable long enough?
answer is yes to all quite obviously you need blutoothe in the helmet to make and recieve calls you would be a bit hard pressed to use speaker phone while boring down the highway
Eh, well, my question was multiple choice... Does it go to "accessory connected" or does it show the iPod info on the display...
