1 - 2 of 2 Posts
My dash lights work around half of the time. I really don't ride that much at night, but it would be nice if they worked all the time. Anyone have a similar problem, or know where to begin looking for the loose connection, bad ground, etc? It's a 2005. Thanks
If it is an 05 those are all LEDs soldered on the main board. There is a sensor that looks at ambient light level that is behind the little dot just above the words "Clock Mode".
Might try to put a piece of black tape over the sensor port and see if that helps. I doubt that an external loose connection could cause that since it is all controlled on that main board.
1 - 2 of 2 Posts
