1 - 12 of 12 Posts
I’ve been experiencing an intermittent cruise control failure. The symptoms began with a failure to reengage after disengaging using the throttle release.
Sometimes I could get it to reengage by closing and opening the throttle a few times, but that doesn’t work consistently. The problem seems to occur most frequently early in the ride before the bike warms up.
Recently, I was on a ride from the Arizona high country starting out at 58F. This may sound strange but the cruise control would not engage until the temperature got up to the mid 70’s after a brief stop. After that it worked fine for the rest of the day.
I’m inclined to believe the problem is related to the throttle cable. I’m considering disabling the throttle disconnect switch. I’ve read that some operators have done this. I typically disconnect using the clutch switch anyway.
Any thoughts?
Thanks in advance for any advise.
Kimble
Phoenix
2000 K1200LT
Your profile indicates you have a 2000 so its probably the throttle cable as you suspect. I would not bypass or disable ANY of the cruise control safeties. That's why they're there. Most, if not all, who have replaced their old throttle cables with the new style say it feels better than new when they're done and are very glad they made the change.
BTW I use the rear brake to disengage the CC. I've always felt that there is some risk over revving if the clutch sensor failed.
Loren
As Loren says, it could be your throttle cable switch, but don't overlook the clutch switch. It is probably the most frequent culprit of this problem, and it is fairly easy to check: If you are in a situation where it has dis-engaged and is not re-engaging (the CC that is!) try pushing the clutch lever forward a little and then re-engaging the cruise. If you can, then the clutch switch is simply a little too sensitive and needs to be adjusted.
I have had similar CC probs in the morning that went away later in the day and it was the clutch switch.
HTH,
My 2000 LT has become problematic in just the same way, randomly drops and will not engage again until the power is shut off at the key-switch, then comes back on again. I was puzzled until one time it was on and I hit a rough section of road at highway speeds and it shut itself off. Now I can determine that if I am over too rough a road while it is powered on but not in use, it will not activate (set) until the bike is powered off and back on again. Of course, my bike has nothing to do with temp because it will do it at 55°f or 95°f.
I would suspect a switch somewhere...
Try loosening the closer cable (up at the grip)a bit and see if that changes anything. Then check the clutch and brake switches. All three are much easier than disabling the switch and don't require tupperware removal.
Thanks to all.
I'm running on the origional cables. Probably should upgrade.
In the mean time, Is the closer cable the upper one?
Thanks again!
Kimble
I had cruise control failure on both my 01LT (now 93K) and my 99LT (now 51K). It would kick out when I would hit a bump in the road. In both cases I resolved the problem by repairing the wire from the speed sensor in the real wheel. The speedometer was getting an intermittent signal, causing the speedometer needle to fluctuate a bit. When I repaired the wire (it was weak/broken at the tiedown just below the seat, near the rear shock absorber) by splicing in a new length of wire, bingo, the cruise control problem went away.
Ok, had to go to Seattle for a new rear tire and decided to test some things. I found if I tapped my clutch lever from the top hard enough to make it jiggle like a rough road would it would disengage the cruise control. If I fiddled with it enough I could get it to reset.
I found my culprit, now to see about adjusting it.
Outstanding! Much easier to fix than replacing throttle cables! Down time is bad time this late in the year. Soon the snow will fly in your part of the world!
Loren
Loren
No kidding... marble-sized hail today, what's up with this?!?!?!
I'll consult the BMW factory manual this week and see what mischief I can get into in adjusting this thing. Shouldn't be too difficult, but you never know with the way this thing is engineered! :D
Discussion Starter #12
It was the throttle switch after all.
Man what a pain to get that close cable adjusted to the correct position. A lot of trial and error, but it works for now in the warmed up state.
Thanks to all and to the Hall of Wisdom.
Gratefully,
Kimble
Phoenix
PS. Getting really anoyed with the 110F+ temps out here! Can't wait for winter!
1 - 12 of 12 Posts
