1 - 2 of 2 Posts
1999 K1200LTC with 75k. I believe my bike has the original spark plugs. When I started to replace them I noticed a couple of the plug wires had been "chaffed" by contact with the plug caps so I am replacing the wires. I already have the wires. There is a cover over the distributor that has one screw that is going to be hard to access. Anyone on this site done this job before and have any advice for me?
I have not done that yet.
When I went to the parts diagrams at MAX BMW, I didn't see a cover on the ignition module. But, by force of habit, I looked at the parts for my 00LT.
Until some can directly answer you question come along, maybe the directions from a service manual might help?
Just in case it has not occurred to you, it is a good time to replace the plugs, and to check the "valve" clearance (when the plugs are out).
I flipped my valve cover gasket over so that I wouldn't have to buy a new one. I doesn't leak.
Best from Gorham ME
Bob
– Remove left-hand side of engine spoiler.
a ....................................................See Group 46
• Remove heat shield (3).
• Pull off spark plug caps with flat pliers.
Removing and installing spark plugs
• Remove spark plugs with spark plug wrench,
BMW No. 12 3 500.
• Installation is the reverse of the removal procedure.
X Tightening torques:
Spark plugs.................................................. 20 Nm
Removing and installing ignition leads
• [Shield housing] Remove screws (1) and lift off
cover (2).
• Disconnect ignition leads from ignition coil.
• Remove ignition leads.
1 - 2 of 2 Posts
