1 - 15 of 15 Posts
Well after seeing one I wanted it. But I kept saying man that is a bunch of money.
While on vacation I ran out of gas. I can give a bunch of excuses, but no excuse for it.
But I made up my mind I wanted to see my instruments again, and move the 2820 off the factory mount.
Needed to strip the right side to chase wires.
Ohhh my God what am I doing?
Well this worked out clean.
Man those mounting holes look huge......
Hmmm, getting somewhere now.
Power for the Mix It Amp for Blue Tooth and the Audio from the Garmin for XM
I am very Pleased with this look from the side.
What Others see, I can live with it.
What I see, OH my it is so sweet.
While waiting for my BMW emblems a 3" Spot mirror to cover the uglies.
This is all that and a bag of chips, with salsa too!.
Couple things.
One the shelf rests on the upper wing-lets, and stabilizes them, a nice thing as my Saeng Spot Mirrors hang off there and the are now very solid.
My bike is very quiet now. Not sure the support on the factory mount is very good for hanging a 2820 off of that sting ray end, it is pretty flimsy. And I also think the shelf is stopping the wings from flapping around.
I LOVE seeing my dash again!!!!!!!
It does shade the Dash from sun.
I had the factory wires shoved up in the OEM factory mount and they were chafed through in an area. I no longer needed it so I cut it off.
This is a super product and puts the GPS in your sight line and allows you to see your dash again. It is VERY solid when mounted and the mounted equipment does not move.
The Sun shade on the GPS is theirs and I have had it for some time. I also use the black moldings on the rear bags. Now the Co-Pilot Shelf with right short arm, and tilting mounting bracket.
Now just have to decide what radar detector I want.
Awesome Products!
I bought my LT used and it had the co-pilot shelf on it. Inside the nose I found a bundle of cables, one of them is the same as the one you have coming from the dash light. What is that for? There was also a cable with a phone type connector on it.
Well the Half moon type is for my Garmin 2820 Power, and the 1/8" plug is for the audio from it's XM to get it to my AUX on my com system.
Without seeing them it is a bit hard to tell but if they are identical to mine I would say you are prewired for a Garmin.
The phone type connection could be just that, or for another electronic device. Radar Detector?
Hope this helps.
Lee,
Great job and great pictures! I'm curious; if you run a stereo cable from the 2820 to the Aux-in on the comm system, do the verbal instructions from the Garmin go to both headset speakers or just one?
Also, what did you use the Mix-It for?
Couple things.
Awesome Products!
GBarnes said:
Lee,
I really cant answer the both headsets question. I really don't use voice prompts much and have it turned off on the Garmin. I also wear a short helmet in the heat of Summer. I would assume yes though. It comes through the external speakers so it should come through the headsets.
I use a Mix It amp for Winter/Distance helmets that are blue tooth. The Mix it boosts that signal and allows me to use my I-pod and the XM as music sources to my blue tooth.
Hi Lee... nice job.
The holes look scary large, dont they!
If I may, a suggestion for tidying up the screw thread & nuts visible from the windscreen side...
I put 4 x black plastic tyre caps on with a little glue, makes it less visible as to how the unit can be undone, and just looks a little more "finished"...
pic 1, pic 2
cheers
cws said:
Hi Lee... nice job.
pic 1, pic 2
cheers
What a great tip! Thank you so much and I am on it.
Great way to finish it!
Thank you again!!!!!!!!
cws said:
Hi Lee... nice job.
pic 1, pic 2
cheers
That is a great idea. I don't have this setup (although I wish I did) but I can apply this idea on some other projects. Thanks!
Just to close this thread I installed the Stick on BMW emblem from Bob's
Odd color from the flash but it is blue...........
I am very pleased with the coving of the OEM mounting holes/Prep for NAV.
Very happy with the BMR product and would recommend it to all.
Nice review I had mine installed at the Last CCR in Utah. :)
I ordered a Co-Pilot shelf and Tilting Mount from BMR and a Garmin Motorcycle Mount from ritzcamera.com. Ritzcamera.com had good pricing and low shipping. The install was as easy as Lee's pictures show. Maybe took me a little more time. I usually move slowly, so I don't mess things up. Still happens sometimes.
I originally installed my 2820 using the temporary adhesive ring and the slide-in mount on the stingray, over the BMW emblem. It worked fine there, but I knew I'd get a shelf eventually.
Not too distract from this thread, @ 5 years ago before BMR came out with the Co-Pilot version I had used the idea of the original and came up with a hybrid of it.
Opted for a horseshoe shape and lower mounting position of the GPS, side wings hold the other farkels such as Radar, Altimeter, Smartire & Camera mount.
* Just sharing other ideas :wave
Scott
My RAM mount mounted on my Radio Controller gave way and fell out. I'm considering adding a BMR Shelf.
LAF, can you please repost your pics to see how you did it?
Rob,
I consulted this thread when getting ready to install my BMR shelf on my new to me LT. The pictures were gone, so I searched the web for BMR shelf. Once on BMR's website, I found this --> http://www.bmrproducts.com/myproducts/CPK1200LT/CPK1200LTInstruct.pdf their installation instructions. Not nearly as nice as the ones Lee (LAF) posted, but functional enough for me to follow along. My install went well. The shelf is easy to install. Those BIG 7/16" holes are hard to drill. Not any problem getting through the plastic. Hard making myself make those big holes in the cowling! Put it in place, wiggle it, hold it tight, wjggle it some more, check that it's in the center of the cowling, press down, mark with a Sharpie, set the shelf aside, and bore some big holes. Once that's done, the rest is a piece of cake.
I didn't take pics of the install, or I'd be happy to post them here.
When I installed mine I used masking tape for marking and drilling the plastic the single best piece of advice that I can give is Take your Time.
You get one shot at getting it right its not at all that complicated but you are forever altering the bike it looks great when done correctly.
When you remove the wind shield make sure you don't lose any of the four fiber washer's if you do go get some rubber washers from a hardware store to replace them.
The bolt's holding the windshield down will have loc-tight on them make sure you clean then and reapply the loc-tight remember a small amount goes along way.
1 - 15 of 15 Posts
