John you could alway donate them to the CCR silent Auction.JPSpen said:Now I have an Autocomm and an Intaride system(s) just laying on the shelf.. I guess maybe I should try to sell them...
That's a good idea, Stevie. Was not sure if the level and resistance coming out of the adapter will work well with earbuds. A quick check with Autocom should answer that, unless you or someone else has direct knowledge/experience with this setup (I sure do not).katnapinn said:Wayne , get ONE OF THESE then ONE OF THESE to connect you earbuds and you will be set.
This is the setup I have on my GTL as I did not want to spend $2400.00 on new helmets & bluetooths to make the bikes Bluetooth work. It reduces the volume enough as not to over power the earbud. Plus you only has to turn the audio on the bike up to 2 or 3 & not GO TO 11 .deputy5211 said:That's a good idea, Stevie. Was not sure if the level and resistance coming out of the adapter will work well with earbuds. A quick check with Autocom should answer that, unless you or someone else has direct knowledge/experience with this setup (I sure do not).
