ICE>link working
I also now have my ICE>link now working and the freeze up problems are gone. I needed to move the ICE>link module to the front of the sidecase from the previous rear mounted position (the back is warmer due to road heat and the tail lights). I found that I had to remove the IPOD mounting cradle from the back of the side case as well and the IPOD is now sitting in an unmounted cradle wrapped in a towel. All of this was worked out traveling across country and not having a continuously working IPOD/ICE>link.
Prior to the move, I had added a strip of 3/4 wide aluminum as a heat sink to the 7805 voltage regulator on the ICE>link module. That did not solve the lock up issues, but the module ran longer in warm weather.
After moving the module, I successfully ran 3 days in warm upper 80's to very hot (death valley at 103 degrees) without any lockup. The longest previous time I was able to run was about an hour. The text display on my 2001 was "okay" but the scrolling was not perfect.
If there is a lock in connector instead of the cradle I will probably get it and then use velcro to mount the IPOD. Based on my experience, I believe there is both a temperature problem with the ICE>link module and a vibration problem with the hard mount.
In the process of shortening the ICE>link cable to less than 1 foot.
I have been dissatisfied with the Dension web page and total lack of response to posted and called in problems. However, I have spent my $200 on the ICE>link and modified it to get it running correctly, so I will stick with it. There supposedly is an option for a 3' cable instead of the 15' cable, but it is not on the web page. Neither is the lock in connector.
