Is there a maintenance procedure on the stand? Mine does not retract all the way and has another 1 to 2 inches to go to it's maximum resting point. Is this normal?
M
Hey,
To me it sounds like you are running out of oil. Have you had any leaks?
The cylinder and pump are a closed loop. There may be a pressure issue, but, I doubt it.
The attached procedure will show how to rebuild it, or just change the oil.
The stand is held on by only a few bolts, so I'd suggest taking it off and rigging a switch and seeing whats wrong.
Good Luck
Center Stand Rebuild Procedure
2011 R1200RT
M
Since your bike is an 06 and still under warranty I would take it to the dealer. You may get a brand new unit out of the deal...
Thanx for the advice guys. I did just get the bike and will hve to check out the dealer for repairs. Probably good to get the brake fluid changed at the same time $$$$$
M
2011 R1200RT
M
You probably don't need to do that yet, since the bike is only 2 years old. The new recommended brake fluid change is every 3 years.
Thanks Gilles, that is the first I heard of leaving it for that long.
