I cannot overstate how much I appreciate this entire great source of info on everything LT. I'm kinda stuck right now. I'm about to upgrade my low beam headlight to a CQlight HID on my 2003 LT. After reading all I could find about this on this forum, I decided to remove the tupperware, all the better to see, for easier finger fiddlin down in the bowels of the headlight assembly. There's real good tips and photos of the actual connection of the HID, but I can't find real detail on any posts about the actual removal of the nose cone. I've got both upper and lower side panels loose, all screws removed, at least all that are visible, and I'm finally at the nose cone. I've got that all loose along both sides too, except it's still tight right at the top (just under the dash panel) I just can't figure out what or where its still tight. I know many of you have been there, done that. Any tips in this regard would be most appreciated. Also, at this point, the headlight assembly is tight in the nose cone, as if that will also come out as part of the nose cone when that finally lets loose. I suppose the assembly must separate from the cone as there will be all manner of wiring attached to it, right? Thanks to any and all for any help you can give me here.
Harleyhoover
Harleyhoover
