I've been reluctant to enter into the fray given all of the knowledgeable posts about slow speed turns with the LT, but what the heck...
I've always been reluctant to slip the clutch on any vehicle, it goes against the grain. But, after 85K miles on my LT (and countless thousands on bikes which I haven't kept track of) I can say that the LT is pretty unforgiving at low speeds. I may hold the record for dropping the LT two up and over loaded with camping gear. :histerica
I eventually came to terms with slipping the clutch at low speed and now do it regularly. My method has been influenced by many of the posts on this site regarding slow speed maneuvers on the LT.
What I have learned to do:
(BTW, my 2000 does not have linked brakes so I can't speak to the response of the linked brake system on later models).
During slow speed maneuvers, I generally will slip the clutch with the throttle set at some constant RPM (not sure what RPM 'cause I'm not looking at the tachometer) and control speed with the rear brake. With the clutch and throttle pulling, the rear brake controls the speed.
I keep my head up and look where I am headed, not down at the road. I do find myself sitting to the outside of the turn to offset the weight of the bike leaning into the turn.
With this method I am much more confident and the bike seems to be much more controllable. Once I am starting out of the turn I let the clutch out and throttle up.
Whatever the physics of the process, I can say it really works better than any method of trying to control the bike with the the clutch fully engaged and all speed control maintained by the throttle. HDs and Goldwings handle much better at low speeds but I'm happy to accept the limitations of the LT at low speed for what it offers once the real ride begins. (The LT will run with the sport bikes like the HDs and GWs can only dream of).
I haven't practiced in parking lots, nor have I taken a rider's training program. But experience tells me that slipping the clutch, holding the rpm's up, and controlling speed with the rear brake gives much greater low speed control on the LT. I find that I now frequently do turns with the steering head at full lock. I'm not trying to get to full lock of the steering head, it just happens with this method.
Yeah, take an experienced rider course, that's good advice. But if you don't get around to it like me, just practice the clutch slip, throttle up, rear brake method and I think you'll find that the LT becomes much more manageable at low speeds.
This is a WONDERFUL motorcycle.
